Liked 83 Times in 32 Posts
I need to know the width of the crank on a small block ford journal. I mean the rod bearing end. I had a crank machined and I think the width is wrong. I know what Chevy and Chrysler is. If someone could please help I would appreciate it.
Herb Jr. |
Liked 306 Times in 103 Posts
Mearsured 3 different cranks all around 1.688-1.690 wide. watch which way rod goes on crank most w's
go opposite of chevy/mopar they're some w's that have rods that go in same direction as chevy/mopar look at bearing should be offset to one side in rod- away from radius on crank.When I grind crank and get call saying it not right normally crank won't turn on fords they have tried to put thrust bearing in rear like chevy instead of center or they start putting rods in locks up,and they have put rods in backwards and bearings are hitting radius on crank.or race crank with 1/8 radius that use chamfered or narrow bearings upper and lower bearings are mixed and hit radius. I don't know your mechanical abilities so if insulted or intelligence I apologize,just thought throw some tips that may help if needed. Mike Taylor3601 |
Banned
Just a word of advice, if you do go to SB Chevy only have the Craank widden to 1.820 the have Rods @.900 wide on Big end, you can ten use the standard SB Chevy bearig just make sure it is chamfered ont the outside of bearing. QUOTE=Mike Taylor 3601;120330]Mearsured 3 different cranks all around 1.688-1.690 wide. watch which way rod goes on crank most w's go opposite of chevy/mopar they're some w's that have rods that go in same direction as chevy/mopar look at bearing should be offset to one side in rod- away from radius on crank.When I grind crank and get call saying it not right normally crank won't turn on fords they have tried to put thrust bearing in rear like chevy instead of center or they start putting rods in locks up,and they have put rods in backwards and bearings are hitting radius on crank.or race crank with 1/8 radius that use chamfered or narrow bearings upper and lower bearings are mixed and hit radius. I don't know your mechanical abilities so if insulted or intelligence I apologize,just thought throw some tips that may help if needed. Mike Taylor3601[/QUOTE] |
