Old 03-19-2009, 09:38 PM   #1
Default Chrysler Lean Burn System
I acquired a 76 Cordoba , 318 /4bbl today . It doesn't even have the "rich corinthian leather" , so I thought I might try racing it in Street bracket.
What does the lean burn system do? Can I disable it..easily? Will it make it inconsistent? Probably,huh?
Thanks in advance
Old 03-19-2009, 09:47 PM   #2
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Default Re: Chrysler Lean Burn System
Thanks in advance
Mark,
My memory is that the lean burn was always an issue and would wreak havoc with any type of spirted driving. I think the kit to replace it was the orange ignition box, two wire something like that, since sold my Street Lil Red. In fact, I think the distributor kit came with the box, and wires. Keep your original ignition piece in your glove box in the event you are stuck on the side of the road.
The mopar performance books do address the dreaded lean burn, you could also look it up on the magazines. If you don't find it within a couple of days, PM me and I will dig through my books etc here.
Good luck with the Mopar.
Eric
Eric Merryfield 1883 STK
Old 03-19-2009, 10:04 PM   #3
Originally Posted by Eric Merryfield View Post
Mark,
Eric
Thanks Eric.
It appears the 76 (first year) might still have centrifical advance and no exhaust gas monitoring.
I see how to de-activate the system with a different distributor and a std type ECU.
I suppose I could just try it as is, but I think we both know what will probably happen.
Old 03-19-2009, 10:20 PM   #4
RockyJ
Hi Mark: Knew a couple of guys who raced those things when new. As a pure stocker type you could not take the air cleaner off or even remove the air cleaner element , it will screw up the mixture and shoot ducks if you do. I setup one car to race and i think had to buy the box that was mentioned, but it has been so long i can not recall what else. Does that one have the quadrajet?
RockyJ is offline   Reply With Quote
Old 03-19-2009, 10:39 PM   #5
I think it's a T-quad, but I don't think it's a feedback type. Maybe if I'm lucky none of the systems will work and the timing will stay put.
Old 03-20-2009, 12:59 AM   #6
ron bretemps
A Mopar mechanic friend told me they backfired so hard while cranking they would brake starter housings!
amxron
none
ron bretemps is offline   Reply With Quote
