Old 03-13-2009, 08:05 PM   #1
blasttime
blasttime's Avatar
Default A Body / susp.
From the experianced have 69 how far off lower bump stop for ride height BBc ? Thanks in advance
blasttime is offline   Reply With Quote
Old 03-14-2009, 10:27 PM   #2
72Malibu
72Malibu's Avatar
Default Re: A Body / susp.
My '72 is between 1/2"- 3/4" off the lower bump stop.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 03-15-2009, 07:48 AM   #3
blasttime
blasttime's Avatar
Was this desired height or just obtainable through wrong spring selection, cutting. Not much travel for those whellies. Are you satisfied with this?
Old 03-15-2009, 08:59 AM   #4
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
72 malibu. does your car have any clearance problems with it sitting so low. headers oil pan etc. can you still drive it at all off the track? I know I could never get my car that low with its moroso springs without cutting them past the point of usefulness. You use Santhuff's I think I've read. any pics of it standing still on 4 tires,lol. looks awesome leaving. thanks, chris
chris ok is offline   Reply With Quote
Old 03-15-2009, 10:55 AM   #5
72Malibu
72Malibu's Avatar
This was obtained with a front end weight of 1925lbs, called Santhuff and they recommended the 200lb springs, they hit it dead on. They would rather you hedge to the light side and use spacers to obtain ideal ride height so as to not lose any of the stored energy in the springs. I have the front end limited some so the wheelies dont get out of hand, yesterday it was leaving good but had the front end back on the ground by the 60ft timers. I dont have any clearance issues, the bottom bump stops are brand new and untrimmed, figured I need the cushion for landing. I use hedman headers and a Moroso 6qt pan with kickouts on either side, so its level with the crossmember.
*** 72 Malibu ***
Old 03-16-2009, 05:16 AM   #6
blasttime
blasttime's Avatar
Thank you for sharing info about the Green Weenie. I have seen the pics of Tony Janes red 68 sure wish him, or those that race similar could chime in. Its eminent these racers have the most efficient suspensions bar none.
