Old 11-18-2008, 09:47 AM   #1
68Coupe
Default Questions about building a stocker
I am thinking about building a 67 mustang for stock eliminator. I don't know a great deal about it other than the very basics. My car is a coupe and I was wanting to build a 390 car. What class could i run with that combo.
I was looking for any tips or suggestions to help get me started. Maybe some suggestions of people that I could contact that could help me out. I live in Virginia, and I called a couple of local machine shops about discussing a motor for stock and they had NO clue. I know I am not going to go out there the first year and set the would on fire just looking to put a mild combo together to get my feet wet, something that will run maybe .5 under. As you can see any help would be greatly appreciated.
68Coupe is offline   Reply With Quote
Old 11-18-2008, 10:24 AM   #2
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Questions about building a stocker
68 coupe,
Get to your closest race track and talk to any guys running Fords in Stock & S/S..Next talk to the current guys running Fords in div 1 & 2...Guys like Bill Hawk, Evan Smith, Duane Eiskant 11 & Tex Miller, Ken Meile to name a few.. Don't spend any $$$$ till you have some idea on what class and engine you can run.. Join NHRA and get a rule book & read it, contact your Div.1 tech guy and pick his brain on combo's.. Good Luck, Dave
Dave Ribeiro 1033 STK
Old 11-18-2008, 10:34 AM   #3
vic guilmino
Liked 56 Times in 21 Posts
Default Re: Questions about building a stocker
i think that car would run c/sa, d/sa and e/sa
where are you in va
Vic Guilmino 1129 STK
Old 11-18-2008, 12:03 PM   #4
68Coupe
Vic I live in Fishersville, it's near Staunton. What part of WV are you. What combo do you run in your Mustang.
Old 11-18-2008, 01:14 PM   #5
Bill Harris
Liked 26 Times in 13 Posts
Good combo. You would run C, D or E. Dave Toren runs exactly that combo and is very quick.
The best Ford FE guy on the planet is Blair Patrick, located near Chattanooga TN. 423-837-1514. Do it once, and do it right.
Vic and I both run '71 429SCJ Mustangs. I always run D while Vic likes to move his around.
Good luck.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 11-18-2008, 05:13 PM   #6
vic guilmino
i live in martinsburg,wv about 3 hrs from you
give me a call and i will tell you where around here to go
301-573-7921
Old 12-10-2008, 01:46 PM   #7
68Mustang
Liked 2 Times in 2 Posts
Question for Bill and Vic and others running big block fords.
Are most of you running a 2.75 1st gear. What rear end gear do you run. I assume most are running 30" Radials, what kind of 60ft times do you normally have.
68Mustang is offline   Reply With Quote
Old 12-10-2008, 08:14 PM   #8
Bill Harris
4.88, 1.40 60' on a good track.
Bill Harris
ex 2172 STK
ex 2272 S/S
