#1 | ||
I'm trying to figure out the best, easiest, safest, and most convenient way to run the fuel line in my Nova. I have it pretty well figured out from the tank to the front subframe, but that's where I can't quite decide what to do. The way I see it is I have three options: run it inboard of the frame rail, inside the frame rail, or outboard of the frame rail. Running it inside the frame rail looks like a pain, so I'm eliminating that option right off the bat. That leaves me having to decide between inboard and outboard. With the small block, I had it inboard, with insulation so that the headers wouldn't cook my fuel. But now that I have a big block and accordingly bigger headers, there's much less room where I had the fuel line before. That leaves me thinking about running the fuel line outboard of the frame rail.
~Pete 1970 Nova |
Liked 306 Times in 103 Posts
Novaman,
I always try to run braided line inside frame only spot that is any trouble is at spring, can drop spring run line and fasten out of way. I also install bulkhead style fitting where original line exits front of crossmember is a little more work but makes for clean installation. When had auto. also ran cooler lines inside frame to front of frame. Mike Taylor 3601 |
I have ran the fuel line on both my novas along the outside of the frame (right alongside of the brake line) and I haven't had any troubles with that on installation or with NHRA tech. You just want to make sure it is strapped in place good just like the brake line is. What classes do you run in? just curious. I am starting a nova stocker project which is new to me so I will some questions at times.
Tim Wilson HR/SST 4301 |
I'm totally classless... or maybe I'm just in a class of my own? I'm nothing more than a lowly bracket racer, but I've found this forum very helpful, and I think I've even managed to contribute something useful once or twice.
~Pete 1970 Nova |
