Old 09-04-2008, 03:13 PM   #1
Chevy454
Default Help! '69 Camaro factory brake setup
I've got a '69 Camaro, bbc w/auto, factory front disc/rear drum setup...my question is for some of you old school guys (read: pre-Wilwood). How can I eliminate the drag on the front/rear breaks? Someone told me of an extra spring on the rear drums to pull the shoes away...and someone else told me to add a small spring between the pads on the front, or even take out the clips and let 'em rattle? I know my fronts are dragging a tad, but the rears may be also.
Any help is appreciated!
69 Pure/Stock Yenko Camaro 11.73 @ 118
Chevy454 is offline   Reply With Quote
Old 09-04-2008, 03:27 PM   #2
ericsz
Default Re: Help! '69 Camaro factory brake setup
Take caliper bolt out and turn them down or sand them down and apply grease to them also if your calipers have inserts for the bolts hone them out also.
Eric Bowling
ericsz is offline   Reply With Quote
Old 09-04-2008, 03:28 PM   #3
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
I am not sure on the fronts, but on the rear you could remove the factory automatic adjuster mechanism and just run the adjuster manually. This way you can determine the clearance you want to run between the shoes and the drum. It will just take an extra pump of the brakes to get them out to the drums.
Chad E532 is offline   Reply With Quote
Old 09-04-2008, 03:45 PM   #4
bobby
bobby's Avatar
You probably have bad hoses or calipers. They are not expensive if you just want to back to stock replacements. You local auto parts store should have them for about $25 per caliper and $20 per hose. I couldn't see the porportioning valve or master cylinder being bad to cause this. And take all the lines loose and blow them out with at least 100 psi of air.
bobby is offline   Reply With Quote
Old 09-05-2008, 12:35 PM   #5
Dave Goob Cook
Dave Goob Cook's Avatar
Can't find it right now, but someone used to offer a set of springs for the calipers that helped retract the pads for low drag.....
Pretty much like a door hinge spring inserted between the pads/caliper to push the pads back......
I'll keep looking to see if I can find the old link.
Dave Goob Cook is offline   Reply With Quote
