Old 08-10-2008, 05:50 PM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Default Cleaning a Body
And I don't mean taking a shower.
Where can you get a car body chemically stripped? I am really not talking about chemical milling, just cleaning the old sound deadener, paint, body filler, rust, etc, so I can work on clean sheet metal. All the places I knew that did that are no longer in business. I understand about the EPA and all that, but I don't want to do this by hand. Preferably in the South.
Thanks!
Dwight Southerland
Old 08-10-2008, 06:41 PM   #2
Woodro Josey
Liked 3 Times in 1 Post
Default Re: Cleaning a Body
Dwight i know there is a place in Atlanta but then thats a way's off for you!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 08-10-2008, 06:56 PM   #3
Wink Re: Cleaning a Body
They are still around but you have to search 'em out -- we have one in nearby Allentown , PA.....
Old 08-10-2008, 07:24 PM   #4
John Leichtamer Jr
John Leichtamer Jr's Avatar
Dwight
Try high pressure waterblasting. Saw a few cars done that way and looked like brand new stamping.
Hammer
John Leichtamer Jr is offline   Reply With Quote
Old 08-10-2008, 07:59 PM   #5
FED 387
Liked 336 Times in 183 Posts
See if you can find a place that does SODA blasting/washing--Saw a old Corvette that a guy did did not hurt the weatherstripping or other soft parts-- Took it right down to raw fiberglass no pits or gouging like you get from sand blasting--Comp 387
Old 08-10-2008, 11:04 PM   #6
Ronnie Hamlin
Liked 29 Times in 8 Posts
Carolina Chem-Strip
333 MacArthur Lane
Burlington, N.C.
336-584-5613
www.chem-strip.com
Ronnie Hamlin is offline   Reply With Quote
Old 08-14-2008, 11:09 PM   #7
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: Cleaning a Body
Dwight:
As I understand it, you want to remove the undercoat from under the floors, is that correct? If that is the case, over the last 30 years or so, I had the occasion to remove undercoating many times. The method I used was to heat the undercoating with a heat gun and use a scraper/Putty knife etc. It is a slow process, but it always works. If you are ever have the chance to see my car, I invite you to inspect the underside of my car. All you will see is a clean underside and a lot of red paint. If your car is completely apart, turn the body on the side. I rolled my car over and rested the roof line gutter on an old tire for support. This did not harm any part of the car and it makes it alot easier to do the job. I was too cheap to buy a rotessery. Good luck on your project. Remember, no one plans to fail, they just fail to plan! A little planning goes a long way!
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 08-15-2008, 12:30 PM   #8
Dwight Southerland
Thanks everybody for the info.
John -
I appreciate your nuts and bolts perspective. I did find a place in Jackson, MS and a place in Ball, LA that do chemical stripping, but I cannot justify all the cost for this project. I am now gathering up materials to do a rudimentary rotisserie and plan on doing this by hand. I probably will do soda blasting after the undercoating and sound deadener are removed.
I have also done a few cars in my time, but this one has an unusually thick layer of undercoating and I was just looking for a easy way out.
Old 08-15-2008, 03:51 PM   #9
SSDiv6
John -
Here you go Dwight...an alternate method...
Old 08-15-2008, 05:44 PM   #10
Dwight Southerland
Wow! I thought I had an original idea!!
