Old 08-06-2008, 12:01 AM   #1
BLIND MULE
BLIND MULE's Avatar
Default Frt.Roller bearing spring perch early Stang!
Anybody use em and do thay offer a drag type spring and what about the 90/10 Cal Tracks?
Thanks
BLIND MULE is offline   Reply With Quote
Old 08-06-2008, 08:50 AM   #2
Bill Harris
Liked 26 Times in 13 Posts
Default Re: Frt.Roller bearing spring perch early Stang!
I use both. The combination is very effective in loosening up the front end. The Calvert 90/10's are the best $100 you will ever spend. You can get both from Alex Denysenko at Moneymaker Racing. If you call him at 219-861-1214 and chat with him he'll probably tell you a trick or two for getting the FoMoCo front end to work well.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
