Old 08-05-2008, 11:23 AM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 2,007 Times in 602 Posts
Default Sealer for leaky heads
I am working on a set of super stock small chevy 441 heads. They are leaking water in the corners of the valve spring pockets due to cutting them out for triple springs. Anybody used a sealer that you pour into the waterjacket to seal the leaks. Any ideas?
Thanks
Mike
Mike Pearson 2485 SS
Old 08-05-2008, 12:02 PM   #2
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: Sealer for leaky heads
If no solution, I have some 441's --- stop by the house and checkem out. Daran 863 604 4868
Daran Summerton is offline   Reply With Quote
Old 08-05-2008, 12:32 PM   #3
SSDiv6
Thanks
Mike
Try the sealer from Goodson.
http://www.goodson.com/store/templat...l.php?IID=5928
Old 08-05-2008, 01:10 PM   #4
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
X2 on the Goodson stuff !!
2894 STK
Old 08-06-2008, 07:03 AM   #5
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
We used Devcon liquid steel. Buy it in pints. Heated it up on a hot plate so it was very liquid and poured it inside the water jacket and turned the head so the Devcon would flow to the spot where the hole was. Prop it up and let it sit overnight. We also would use the same stuff under a spring seat shim on top of the hole. It works for a while but might weap a little. We also tried some epoxy type automotive paint poured in the same way....It's real easy to pop a hole in the end spring seat pads on many SB Chevy heads. If you limit the depth of the cut with a .060" stock spring shim and put a radius on the seat cutter it helps reduce the chances of hitting water.......
Rich Biebel
S/C 1479
Stock 147R
Old 08-06-2008, 10:20 AM   #6
Mike Pearson
After careful inspection I found the spot where the leak is located. It is in the spring pocket where it got thin after machining for the big springs. We used the 060 shim but still cut through in several pockets. Those repairs were made with brass. The radius cutter probably would have helped. Great idea!! I am going to either braze or silver solder this leak. Anyone have any suggestions. Then we will probably use the goodson sealer after the welded repair.
Thanks for the help.
Mike
Old 08-07-2008, 09:12 AM   #7
Dave Goob Cook
Dave Goob Cook's Avatar
K-W Metallic Block Sealer works well in assembled, hot engines, per directions, and it's permanent.
Dave Goob Cook is offline   Reply With Quote
Old 08-07-2008, 05:22 PM   #8
larry lomascolo
Guest
Posts: n/a
i brazed a leak closed ,it has held for years,,,good luck
Old 08-07-2008, 05:32 PM   #9
larry lomascolo
Guest
Posts: n/a
Old 08-08-2008, 01:50 PM   #10
Aaron Keown
Aaron Keown's Avatar
Whatever type of sealer you decide to use,the best way to get it to seal properly is to block off the water jackets and put the head under vacuum so that you can suck the sealer up into the crack/hole.This is how professional crack repair shops do it.
Aaron Keown is offline   Reply With Quote
