Old 07-31-2008, 11:20 PM   #1
Brett Brown
Liked 5 Times in 2 Posts
Default Scat 5.7 Connecting Rods
What are the opinions of a Scat 5.7 Connecting Rod for a Super Stock application?
Thanks.
Brett Brown 7257 STK, SS, COMP
Brett Brown is offline   Reply With Quote
Old 08-01-2008, 03:04 PM   #2
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default Re: Scat 5.7 Connecting Rods
They may be fine, but I'd buy Manley's. Its a peace of mind thing.... spend it once, ya know. My original engine builder, convinced me, and I'm glad he did.
I better go find some wood to knock on , now that I said that......
2894 STK
Old 08-01-2008, 06:18 PM   #3
63corvette
Liked 362 Times in 105 Posts
You get what you pay for in most cases.
Any of them can fail. I pulled the eye out of a Manley connecting rod back in the 1990's. Manley did give me a new full set of rods but I still lost a block and a couple of pistons and cam in the deal.
My 2 Cents
63corvette is offline   Reply With Quote
Old 08-01-2008, 07:53 PM   #4
Bub Whitaker
yup...no matter what you buy, **** happens. I've seen them all fail...but if you check them when you get them completely/ big end / small end/ length/ Mag, you might ward off some problems...would'nt belive what I've seen in the past 35 years from all of them...
Bub Whitaker is offline   Reply With Quote
Old 08-02-2008, 12:57 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
So true Bub...
Had a customer want to supply his own parts for a BB SS engine. He furnished all the parts. He did get a name rod, but they were out of parallel big end to little end about .006.
Try to explain that when checking the deck height. You have to check & recheck any brand.
Adger Smith (Former SS)
Old 08-02-2008, 09:55 PM   #6
Bub Whitaker
Originally Posted by Ed OBrien View Post
This may be a little off the subject but I've seen more after market BBC rods in Stock Elim. engines fail than I've seen GM rods with good bolts and good machine work done fail . I've treated some GM rods real bad over the years with heavy pistons and still had good luck and I've twisted them pretty hard so am I missing something here or are GM rods just better metal ? Have a nice day
No Ed your not missing anything...properly prepared stock rod are just fine to a point. Piston weight and RPM will take a toll on any connecting rod...
