Liked 5 Times in 5 Posts
I took my 327 small block to be machined for 50mm roller cam bearings, and when they cut my oil groove .070, they busted into the water jacket.
How deep should this have been? .070 seems a bit too deep. They want to fix with JB weld. Has anyone ran into this to give me some help/advice? I am sick....... |
Liked 101 Times in 27 Posts
call Performance Specialties---Doc Bilbrey-----919-894-3671
Liked 1,967 Times in 595 Posts
The block probably had alot of core shift. OEM blocks vary alot in casting thickness. Any fix with epoxy will not last. you probably should start over with a different block. If you are running super stock I would recomend a bowtie block.
Mike Pearson 2485 SS |
I used old "010" chevy blocks for my ss engines and when I asked my machinist about cutting the block for the 50 mm cam he warned me not to try that. "Not enough meat in those old blocks". You need to use a bowtie block.
Jesse Knapp 4899 STK, SS |
Thanks fellas.
I am a newbie, but can I run any SBC 4.000 block with a 3.25 stroke, or will that put me into the GT classes? Will a Bowtie block put me into the GT class? Not that it matters a whole lot, but I just to know....... Last edited by JeffM; 06-17-2008 at 11:20 AM. |
I don't think I'd trust the JB Weld either. Nothing against the product, I've used it many times successfully, but I wouldn't use it in a cam bore area. You can use the old chevy "60's" blocks, the newer ones, or a bowtie piece. Bowtie is the way to go, but pricey. Has to be the 4" bore for 302, 327, and 350 with the .070 allowance for superstock. You can run the natural classes or the newer gt classes depending on what body style you want to run. You can run the pre 80 cars in gt now. Example: If your car is a 68 camaro and you run the 327 engine, one of a few choices offered in 68 from Chevrolet, it has a natural class in superstock and is allowed to run a gt class if you choose to go that way. I've seen very few old camaros, or old cars period, in gt. I doubt there's much, if any, advantage there. Hope this helps.....
