Old 04-28-2008, 05:46 PM   #1
kirk
Liked 5 Times in 4 Posts
Default Trunk Mounted Battery Rule..........
Hey guys I am building a new car, and need to know about the rule for sealing off the trunk area. If I run a moroso sealed battery box, and vent it outside the trunk area, do I also have to run the steel or aluminum plate between the trunk and rear seat, or is just the sealed box legal?
thanks,
Kirk
kirk is offline   Reply With Quote
Old 04-28-2008, 05:57 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Trunk Mounted Battery Rule..........
No!!!
Old 04-28-2008, 07:13 PM   #3
FED 387
Actually first ? NO--Second ? YES---Sorry to confuse you---Just remember to follow NHRA rules regarding fastening the box to the gtrunk floor---Comp 387
Old 04-28-2008, 07:43 PM   #4
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Are you planning on using a fuel cell? If so, you will need to seal off the trunk from the driver area.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 04-28-2008, 09:39 PM   #5
kirk
sorry about that guys, I am running the stock gas tank.
kirk
Old 04-29-2008, 02:13 PM   #6
Run to Rund
Liked 54 Times in 27 Posts
The rules state that if you RELOCATE the battery to the trunk, you need a cut off switch. What if the battery originally came in the trunk from the factory? Can NHRA require adding the cabling and switch to a STOCK setup?
