Old 04-27-2007, 04:41 PM   #1
Stock 5 point 0
Default 5.0 Mustang Stocker ???s
I am new to this board. I would like any info you guys could give me on building a 5.0 Mustang for Stock I will be running a automatic. Any help would be grate. Also if you know of or have any parts for sale that might help me that would be good to. Thanks
Stock 5 point 0 is offline   Reply With Quote
Old 04-28-2007, 04:12 PM   #2
SSDiv6
Default
First, for starters, you need to tell us the year of the car. Work in the suspension first such as reinforcing the boxes and installing aftermarket upper and lower control arms, frame connectors and a roll bar. As an autoamtic car, you need a good C-4 trans. You also need to get rid of the cC-Clip axles too, along to installing a good limited slip or spool and appropirate gears.
Old 04-28-2007, 05:29 PM   #3
Brian Holcombe
Default
I would contact Evan smith
Second i would get ahold of Wild-rides in Famingdale NJ for info on the suspension reinforcements (battle boxes) and control arms.
Brian Holcombe is offline   Reply With Quote
Old 04-28-2007, 05:59 PM   #4
Stock 5 point 0
Default
I will be useing a 89 GT I allready planed on doing the roll bar and the susspension stuff. I would just like to here what other guys have to say. So I do not waste money and time .
Old 04-28-2007, 07:28 PM   #5
SSDiv6
Default
Based on my research of chassis parts out there, the best frame connectors and roll bar I have found in kit form are from Wolfe Racecraft. Wild Rides makes the best reinforcement kit. For uppers and lower bars and front control arms bushings, I would go with Global West; the rules requires a non-adjustable lower bar; only the upper can be adjustable. Front springs Moroso, rears OEM springs. For shocks, Lakehood, QA-1 or Tokico drags work.
Old 04-30-2007, 02:19 PM   #6
Chris1529
Liked 70 Times in 29 Posts
Default
You definately need the subframe connectors. I believe your car fits a class which does not require a roll bar if you don't feel the need to have one. I would concentrate on the proper gear, tire, and torque converter selection. You will benefit most from those items after the subframe connectors.
Chris B
K/CM 1984 Mustang GT350
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 04-30-2007, 10:08 PM   #7
Larry Ingram
Default
5.0
If you would send me an e-mail with your address and phone I will retrun a call. I may have some new pieces you may be interested in for your combination. Larry Ingram, lingram@watsonquality.com or racingfrog56@aol.com
Larry Ingram is offline   Reply With Quote
Old 05-02-2007, 07:24 PM   #8
Stock 5 point 0
Default
Come on guys there gotta be more guys running Mustang 5.0 Stockers. Please more input
Old 05-02-2007, 09:53 PM   #9
Stock 5 point 0
Default
Larry I e mailed you did you get it?
Old 05-02-2007, 10:09 PM   #10
Chris1529
Default
I don't think the suspension is the most critical part of your build up. At most, I would put adjustable shocks and struts on it and sub-frame connectors. spend your money on the fuel system and fuel injection system. Geet that right with a good converter and the right gear and you will be happy.
Chris Bowman
1984 Mustang GT350
