Guest
Posts: n/a
I need a little help in getting my AVS to work right.
I am running a 70 340 in Pure Stock. I have a stumble / bog on the launch that I can't fugure out how to get rid of. I am not an expert on carbs, so any help would be appreciated. I have tried different accelerator pump linkage positions, larger and smaller squirters, larger jets and adjusting to the air valve. None seem to completely cure the problem. The air valve seems to help best, if I put enough preload on the spring, but the stumble is still there. Any suggestions would be appreciated. Thanks Mike Coates IHRA 3914 D/PS swinger Mike Coates |
#3 | |
Liked 13 Times in 5 Posts
Been a while since we ran the AVS's, but you might try closing up the oval-shaped holes in the flappers, if it's legal of course. This helped throttle repsonse with our Max Wedge. We used duct tape at first, then epoxied wire mesh over the holes. Meyer Family Racing '64 Plymouth Max Wedge '65 Dodge - rebuilding for ?? N/SS S/ST & H/R 3426
Meyer Family Racing (re-tired) 1965 Dodge Coronet - Steet car and Part-time N/SS 1962 Plymouth Fury S/ST #3384 - Race in Peace, Craig Meyer |
Liked 265 Times in 69 Posts
Make sure the air valve is tight enough. 1 1/2 to 2 turns should help.
John Dinkel 3295 STK |
Try a new spring on the air valve, sometimes when they are weak the door will snap open and not open gradually. I chased that problem on a TQ, new spring stumble was gone. AVS's can be tricky, they don't have a vacuum diaphram to delay the air valve opening.
Also the carb may be to lean, try jetting up the secondary side. Make sure the primnary's are open 1/2 - 3/4's before the secondaries. I had one that must have been a marine unit and the primary's would open about 1/4 and the sec. would start to open. I tried everything and could not get the stumble out. It was the only AVS I ever saw that did that. Chuck Beach is the guy to talk to about AVS's. When you get one right it will work great.
GEORGE MIRZA STK 1236 |
Liked 327 Times in 121 Posts
Hey George, Whats cookin
Guest
Posts: n/a
Thanks everyone for the input!!
I will try out the suggestions and determine where to go from there. Thanks again! Mike Mike Coates |
Hey Paulie, long time no see!
I don't get out as much as I used to. Hows life in PA? I still see Lenny once in a while and Howard and I still run quite a bit up here. The only race we go to down your way is the Dutch. I miss the Mopar Nats. How about yourself, your in the thick of it now, when are you going to get out. George
I have worked on these carbs for about 30 years, part of the problem is the accerator pump, I make my own. I can send you one for about $30.00. I run a '68 340 cuda in G/SA, have gone 11.0's, but I leave on a 2 step, but can still go back to foot braking. The secondary air valve needs to be tight, if it binds up, replace it with another one. If you want me to go thru it I charge $350.00. good luck
Chuck Beach 3340 STK |
Chuck , Would you send your email to me at aaaltd@sasktel.net Would like to talk about an AVS. Thanks Glenn Person
Glenn Person 5356 STK |
