Old 07-09-2018, 07:25 PM   #1
cummins
Liked 27 Times in 8 Posts
Default alternator
Who's one wire alternator would be the best one to use for a stocker?
Thanks
cummins is offline   Reply With Quote
Old 07-09-2018, 08:21 PM   #2
Liked 1,930 Times in 435 Posts
Default Re: alternator
I've had good luck with PowerMaster.
Old 07-09-2018, 08:25 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: alternator
I've had great service from PowerMaster as well. Mine is the smallest 50amp they have and I do have to charge between rounds to keep the battery topped off. But I figure it takes the least amount of HP while still being functional.
LOCOMOTION Racing
Old 07-09-2018, 08:26 PM   #4
Dana Fitzpatrick
Liked 10 Times in 6 Posts
I agree with Alan. I've also been very happy with their customer service.
Dana Fitzpatrick is offline   Reply With Quote
Old 07-10-2018, 12:08 AM   #5
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
PowerMaster X4 here!
I've been experimenting with pulleys trying to get a balance between charging rate and parasitic drag. Also looking at a WOT cut-out switch to see if there's anything there.
Lew Silverman #2070
"The Wagon Master" N/SA
Old 07-10-2018, 08:34 AM   #6
Bobby DiDomenico
Liked 104 Times in 53 Posts
I think that's the better way to go rather than too small amperage wise.
Old 07-10-2018, 09:51 AM   #7
cummins
Ok guys thanks for input i will pic one up
Old 07-10-2018, 02:09 PM   #8
Ed Wright
Ed Wright's Avatar
Lew, a normally closed relay in that single wire, connected to a universal starter button under the accelelorator pedal makes it "old man forget proof". Pedal on the floor opens that normally closed relay to disable the alternator. Some EFI car ECUs have some AC clutch code that can be used to open that relay above a chosen RPM, etc.
A switch could also be mounted by the carb, to kill it @ WOT, but would also be just one more thing to deal with during tear downs, and working on the engine.
I finally just went to 16 volts.
Ed Wright 4156 SS/JA
Old 07-10-2018, 02:31 PM   #9
Mark Lewis
Liked 210 Times in 47 Posts
Contact Mark at House of Payne, he can get th Powermaster up to 75amps in the small version. I like this one for EFI to have the charging capability.
Mark Lewis is offline   Reply With Quote
Old 07-12-2018, 12:00 PM   #10
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Gee whiz,
All this time I thought that was illegal???..
Silly me...
Bob Mulry 7516 STK
A & M Motorsports
