Old 05-21-2025, 10:23 PM   #1
1214
Default Steering Shaft
Does anyone make a steering shaft for a Vega steering box to a stock 1990 Camaro column using block and pin U joints and moly tubing. Ed Quay made these at one time but no more.
1214 is offline   Reply With Quote
Old 05-22-2025, 04:30 PM   #2
James Perrone
Liked 1,865 Times in 435 Posts
Default Re: Steering Shaft
Borgson. Or try speedway
james perrone 1290 STK
Old 05-22-2025, 05:59 PM   #3
SSDiv6
The Vega steering box is not recommended for cars that exceed 3000lbs in weight and that also wheel stand.
Borgeson sells a better steering box and you can use your current steering shaft.
https://www.borgeson.com/78-88-Malibu-82-92-Camaro.html
They also have a replacement steering shaft.
https://www.borgeson.com/G-Body-F-Bo...ing-Shaft.html
Old 05-23-2025, 01:41 PM   #4
James Perrone
I have a couple of Manual s10 steering box?s for sale. Bolts right in
Old 05-24-2025, 10:59 AM   #5
Eman
Liked 133 Times in 76 Posts
The S10 box will bolt right in and use the factory pitman arm, I ran one on my 85 F body for decades. you can buy the joints and make a shaft. I ran the factory shaft on mine.
Eman is online now   Reply With Quote
