Old 10-24-2023, 03:21 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default C 25 fuel.
I normally run Renagade 110 fuel. Because of price and readily available where I buy it. With all things being equal is 25 faster for heads up runs? I run stock eliminator. 350 cu inch.
Kdw1403 is offline   Reply With Quote
Old 10-24-2023, 03:48 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: C 25 fuel.
Too many Variables for a blanket answer.
Your engine may not like the makeup of that fuel.
It may slow you down.
Adger Smith (Former SS)
Old 10-25-2023, 10:39 AM   #3
Darcy Clarke
Liked 511 Times in 35 Posts
I have ran C25 with great results my SuperStocker Loves it but it has significant compression. The only way to find out is to give to the track with a couple of pails and test changing timing and jetting to optimize. For me in my Stocker I run it at Indy with good results and in My SuperStocker with great results. Good luck with your testing!
Darcy Clarke
6254 A/SA SS/EA
Darcy Clarke is offline   Reply With Quote
Old 10-29-2023, 01:37 PM   #4
Liked 1,789 Times in 408 Posts
You cannot simply pour in a different fuel and expect to go faster.
C-25 has a faster burn rate. It requires less timing, etc, than C-12, C-14, etc. It also requires a different A/F ratio. And it won't necessarily automatically generate the same or the correct A/F ratio for your engine. It will require serious tuning. It probably won't do anything for a lower compression (below 11.5:1) engine.
