Liked 84 Times in 21 Posts
How much effective change to alignment is there when changing ride height. More specifically on first gen f body when raising ride height how does that change camber? Will it create more negative camber or will it create more positive camber? Also what direction will the caster go, towards positive or negative?
Liked 7,742 Times in 1,740 Posts
Raising the ride height on an early Camaro will make the camber go negative.
Depending on how much you are raising it, it may not be an issue.
