Old 07-29-2023, 02:19 PM   #1
BrayJo
Liked 6 Times in 5 Posts
Default Car sputters on the 2 step
I have a brake pressure switch and a chipped MSD7al2. The problem is intermittent. What should I be looking at first? Suggestions?
BrayJo is offline   Reply With Quote
Old 07-30-2023, 12:34 PM   #2
Eman
Liked 133 Times in 76 Posts
Default Re: Car sputters on the 2 step
Check the BP switch. I have a small LED in the circuit so I can see that the circuit is working. If the switch isn't making good contact inside it could effect the 2 step. Of course like most electrical problems always check every ground.
Old 07-31-2023, 11:52 AM   #3
BrayJo
I got 13 volts to the MSD box when I press the brake and activate the switch, so it appears it may be a MSD issue.
