07-11-2023, 05:33 PM | #1 |
Master cylinder
I have Strange duel calipers at the rear and Mark Wiliams single calipers at front, have strange mastercylinder 1,125, is it to small master cylinder? I think i have long way for the pedal.
Thanks, Torbjorn |
07-12-2023, 03:43 PM | #2 |
Liked 685 Times in 293 Posts
Re: Master cylinder
My car has Strange duel calipers in back Strange singles in front. I have a Strange master cylinder but I don't remember what size. No problems but I do run 2 PSI residual valves front and rear and that helps me keep a good pedal.
All hard lines except for -3 from the frame to the wheels. However I may be causing some brake drag with those valves, don't know. |
07-12-2023, 08:47 PM | #3 |
Liked 396 Times in 126 Posts
Re: Master cylinder
Dual rear Calipers require larger volume than a single fronts. I would call both Strange and M W and confirm piston volumes. Ask Strange which port , front or back has more volume output and tube it accordingly. Based on the Piston areas , Strange should tell you if MS bore size has enough volume.
Steve Teeter Stk/SS 620 |
07-13-2023, 08:17 AM | #4 | |
Liked 181 Times in 111 Posts
Re: Master cylinder
Have a New WIldwood Master Cylinder for sale. Dan |
07-14-2023, 10:39 PM | #5 | |
Liked 760 Times in 211 Posts
Re: Master cylinder
