Liked 207 Times in 44 Posts
Are the new Goodyear 9 inch radials the fastest tire and how about reliability and longevity. Thanks for input
Liked 10,720 Times in 2,232 Posts
I get great life out of the Goodyear’s and the car hooks if we have any kind of track for the pink car 3200# car with close to 600 ft/lbs of torque. On Dumbo I have not gotten the repeatability down with the longer wheel base and heavier car with 100 more Hp.
A 100 plus runs is not a problem. The service and support at the track is very good. |
Liked 685 Times in 204 Posts
I had 96 runs on my Goodyear tires on my A/SA 2019 Challenger. Like Larry said, the longer wheel base can be a challenge at times, but I was very happy with them.
Mark,
I went to the Goodyear's on Terri's Nova and will NOT go back to the Hoosier's. They are as fast and last much much longer. I put them on Terri's new car as well when I moved her to the automatic. I won't run anything else. Keith
Keith A/S 2990/Terri A/SA 2991 "Imagine what you'd attempt, if you knew you could not fail!" |
#5 | |
Liked 972 Times in 309 Posts
1989 Camaro Iroc-Z I/SA B&B Auto Machine Shop. Last edited by Glenn Briglio; 10-29-2022 at 08:55 AM. |
#6 | |
Liked 269 Times in 99 Posts
Glenn if you do a search Larry gave all that info in the past. It sure is worth a try.
Glenn it’s the big tire 94†roll out. With the taller tire I think I get more of a contract patch due to elongation on tire deflection. For me and the car to be in the 3200# range I have to be in the 250# range.
Liked 2,486 Times in 697 Posts
We run Goodyear Radials on all our stock and Superstock
cars!
#9 | |
Liked 455 Times in 147 Posts
Steve Teeter Stk/SS 620. |
9" rim width I meant.
