Old 09-14-2022, 02:41 PM   #1
gnicholson
Liked 4 Times in 3 Posts
Default dedenbear box
im using an older dedenbear delay box tstop timer in my s street car. i havent had it checked for calibration tested etc but im not having any problems with it. just wondering if there is any advantage to replacing it with a new unit. can the electronics degrade over time etc.
gnicholson is offline   Reply With Quote
Old 09-19-2022, 06:18 AM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: dedenbear box
There are some who argue that the really old boxes were better/more accurate. I don’t know if I believe that, but if your old box is working fine, I wouldn’t worry about it unless you are lacking features you would like to have.
I’d wondered where you’d been at some point during this season, so it was good to see you going rounds in Earlville!
S/ST 51
S/C 53
Old 09-19-2022, 12:47 PM   #3
Steve Stasko
Liked 272 Times in 142 Posts
Is it a thumbwheel box? I was told to periodically cycle through the entire range of the wheels just to keep the contacts clean. Other than that, mine has always been good to me.
Old 09-20-2022, 10:33 AM   #4
SST159
Liked 20 Times in 16 Posts
This is an interesting and ironic subject.
I have been chasing erratic reaction times since mid summer this season.
I use the Dedenbear Lightning plus in Pro Tree (NHRA Super Street) trim.
Historically I would carry between .095 to .105 in the delay box for several years which normally would put me in the .0 teens to low .020’s
Now all the sudden first two hits I would see average mid-teens in reaction time which is common but then first and second round bang huge swing in high reaction times. (yes I got lucky and still won the round)
Now I say to myself know I am getting old but not consistently old LOL however round two I find a very similar high reaction time.
This has been going on the rest of the season.
I have since replaced the Trans solenoid and made no difference.
Then I changed the button using the same brand button (Biondo Double 0 button) and no difference.
My question is has anyone ever experienced delay boxes going bad?
I did call Dedenbear and they told me anything could be possible and to send it to them and they would check it out.
The trans temp is all staying normal so I don’t think heat is culprit.
The converter is my next direction, but the data recorder does not show any change from older runs.
Just looking for anyone with similar experiences and what they may have found to be the culprit.
Any suggestions?
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 09-20-2022, 03:50 PM   #5
Lenny5160
Lenny5160's Avatar
Anything is possible, but it doesn't intuitively make sense that a bad delay box would produce a repeating pattern as far as not doing what it is supposed to do. It isn't like the box gets hot the more you use it.
S/ST 51
S/C 53
Old 09-23-2022, 11:30 AM   #6
Charlie Yannetti
Liked 191 Times in 82 Posts
My car was originally built in 1996, and one of the "OLD" blue K&R boxes was installed.. it was marketed by Biondo Racing back then.. fast forward 25 years, and I began questioning the box, as well as its capabilities.. sent it to K&R, they checked, and sent back a report that it was as good as the day it was built..
Being a doubter, I rewired the car in 2020, and installed a brand new K&R Pro Cube.. put all the numbers in from the "OLD" box, and lo and behold, same results.. nothing wrong with the "OLD" box..
My point being, change your box for piece of mind, but I doubt your problems are contained in your box..
BTW, I still have that "OLD" blue box, should anyone be interested..
Charlie Yannetti is offline   Reply With Quote
Old 09-26-2022, 09:16 PM   #7
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
I`m running an RTD-7 in my car (purchased a couple of years ago- the RTD-6 was starting to act up) and have the old 4 stage throttle timer and both seem to be working exceptionally well.....Super Street or Super Pro
Lane Weber
Old 09-28-2022, 06:00 PM   #8
gnicholson
thanks tony allways great to see you
Old 09-28-2022, 06:07 PM   #9
gnicholson
the box im using is push button not thumbwheel. like any electronics i think heat could effect an electronic component going bad and cause erratic switching speeds. in my mind checking the calibration and operation isnt a bad idea if you have access to the equipment or just send it to someone if you suspect problems. i just thought i would get other opinions
