Liked 16 Times in 6 Posts
Is there an approved antifreeze for NHRA race engines?
Jeff Davison 6047 Stk/SS |
Liked 753 Times in 213 Posts
I think the Evans coolant is still approved.
https://www.evanscoolant.com/Custome...hra_letter.pdf |
#3 | |
Mr.Davison,
It's a 2018 letter from NHRA so I'm not 100% sure... Here the link on the Evans website: https://www.evanscoolant.com/nhra/ |
#5 | |
Liked 1,583 Times in 582 Posts
The issue is with Ethylene Glycol based coolants. Difficult to clean spills and many times, more difficult to clean than an oil spill.
On the other hand, NASCAR allows the use of Propylene Glycol based coolants. It dissolves easily with water and is non-toxic. AMSOIL Antifreeze & Engine Coolant is formulated with propylene glycol. Indeed, the Evans Coolant is NHRA approved. Also, Summit Racing has a non-Glycol-based coolant specifically for racing. You can also run distilled water with two bottles of a wetting agent such as Redline Watter Wetter, Royal Purple Ice, or Pro Blend Below 40. |
#7 | |
Liked 1,032 Times in 368 Posts
https://www.drivenracingoil.com.au/p...tem-protector/
Jeff Niceswanger 3740 SS |
