Old 09-14-2022, 08:38 PM   #1
DailyDriverSst
Liked 7 Times in 6 Posts
Default S/ST - 3.89 vs 4.10
I am switching from a Chrysler 8.75 to a Ford 9 over winter. Just can't get 8.75 stuff anymore.
Right now I have a 4.10 gear and go through the traps at 6,000 RPM. I am debating ordering the new axle with a 3.89 gearset instead of 4.10 . Have a 1.98 low in the powerglide.
How much can I expect my short numbers and ratios to change, if at all?
Converter stalls to 4,000 RPM and it's a factory frame rail truck with full interior.
TIA
DailyDriverSst is offline   Reply With Quote
Old 09-15-2022, 03:40 AM   #2
GTX JOHN
Liked 2,425 Times in 687 Posts
Default Re: S/ST - 3.89 vs 4.10
Not a bunch
Couple hun short times
John Irving
741 Stock
741 Super Stock
Old 09-18-2022, 10:50 AM   #3
Charlie Yannetti
Liked 191 Times in 82 Posts
Not sure of your engine combo, but 6000 sounds low to me.. it does depend on the power though.. I might be looking to go up, instead of down..
Charlie Yannetti is offline   Reply With Quote
Old 09-19-2022, 06:24 AM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I agree that 6000 RPM sounds like the low range of acceptable converter stall numbers rather than an excessive trap number, but I suspect the “DailyDriver” part of the OP’s handle has something to do with this.
S/ST 51
S/C 53
Old 09-27-2022, 07:57 PM   #5
DailyDriverSst
You would be correct. This is also a factory casting 2-bolt block that I'm almost asking too much of. Don't really want to hang the rods out of it, and I put 2-3,000 miles a year on it between taking it to work, joy rides, Rocky Mountain Race Week, etc.
