Old 12-23-2021, 03:22 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default SS/SBC 1970 350/360 or 370
Racers,
I am considering building a SS/GT with the 350/360or370. I like that combo because of the Holley carb, dome piston, and bigger valves. [all good things].
*The Car would be my 1982 Camaro Lamplighter because it will take only a few minor changes to make that body legal. Plus, they are proven, performers.
Questions:
*The specs I see are mostly the same for the 360 or 370 engine, so I expect the 360 factored to whatever is the best choice.
*A number of the classic SBC heads are legal. Does any casting hold any advantage? The heads with the bolt holes on end are convenient. I intend to use OE castings, not aftermarket.
*I am open to any experience or thoughts.
Thanks, Larry Woodfin
Larry Woodfin 471W
Old 12-23-2021, 04:29 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 971 Times in 308 Posts
Default Re: SS/SBC 1970 350/360 or 370
Originally Posted by Dragsinger View Post
Racers,
Questions:
370 hp manual only and rated at 355
Old 12-23-2021, 06:30 PM   #3
Dragsinger
Thanks, Glenn, I overlooked the manual trans designation. so the 360 it will be.
Larry Woodfin 471W
Old 12-24-2021, 10:41 AM   #4
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: SS/SBC 1970 350/360 or 370
Racers,
Questions:
Good morning Larry,
From my past experience the 1.94/1.50 #186 Chevrolet castings are a very good starting point, as long as they aren't cracked! They can be upgraded to the 2.02 / 1.60 valves and then you're starting with the valve seats in fresh metal. The #186 castings I've found to be the best flowing factory heads for a Small Block Chevy (with the small chambers). I would suggest that you give Glenn @ B&B Auto machine a call if you need further information.
Good luck with you're build.
Respectfully,
Henry Kunz 1534 H/SA
Last edited by Henrys Toy; 12-24-2021 at 11:13 AM. Reason: P.S. Don't pass on a good set of #041 castings if they come you're way.
Henrys Toy is offline   Reply With Quote
Old 12-24-2021, 10:47 AM   #5
Hacksaw
Liked 310 Times in 174 Posts
For SS you can use any head that's on the accepted list. After all the welding and epoxy they all come out the same. Just stay away from any casting that has a history of cracking.
Old 12-24-2021, 11:20 AM   #6
Dragsinger
Thanks, Guy's I already have my dogs looking for castings.
Larry Woodfin 471W
