Liked 10,687 Times in 2,225 Posts
Don’t forget to check the tires for age. Old tires will let you down on a hot day. We carry a mounted spare for the truck and trailer. Mounted spares will save time and money.
Liked 800 Times in 337 Posts
In my case the calendar advances faster than the odometer on my truck and trailer tires.
It kills me to replace tires that have so much tread on them. However experience has told me it is necessary. |
Liked 309 Times in 173 Posts
Also a good time to check your trailers running gear. Just freshened mine up.
Liked 216 Times in 77 Posts
Just a tip. But when your not using your motor home and trailer. If it’s not parked inside. Cover the tires. They’ll last a lot longer before they start cracking from the sun. They make covers for them. But a Black Friday $.89 sheet works too if your cheap like me.
#5 | |
Liked 251 Times in 125 Posts
#6 | |
Edit: I got to wondering so I googled why tires on a sitting vehicles dry rot faster than a vehicle being used. It’s because tires are kept moist by the oils and resins in them. And they need the pressure of being used to activate them. (That’s the short version) can’t figure out how to post a picture of the whole explanation or I would. Last edited by Rob Petrie E395; 12-03-2021 at 10:18 PM. |
Liked 133 Times in 76 Posts
I keep 2 mounted spares for the trailer, and I have an extra for my truck too if I travel any distance. I keep my tires covered when trailer is parked and still lost a tire recently, 2 years old and I didn't race last year so minimal miles. Blew out the back sidewall.
If you took your trailer for a short spin every month the tires would not crack as quickly? I will try it anyway. It will be way cheaper than buying tires.
Liked 126 Times in 61 Posts
If to raise your trailer off the ground in the off season they will last longer. Having weight on them sitting in one spot for 5 or 6 months will make them blow out faster. I used trailer legs or jack stand on my tag for years. Cured the 2 -3 year all the tires started to blow out. On the gooseneck I have now, I just lower the front down as far as it will go then put jack stands under the back of the frame and then raise the front back up. All tires are now off the ground. Tires will last much longer.
#10 | |
sense. I guess they need to be heated occasionally. Thanks |
