Old 11-12-2021, 10:53 PM   #1
madman9
Liked 3 Times in 1 Post
Default Valve lash
I bought an lt1 stocker engine and it seams like the valve lash is .005” is this normal thanks
madman9 is offline   Reply With Quote
Old 11-13-2021, 02:58 PM   #2
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Default Re: Valve lash
You really need to find out who the cam grinder is and talk to them. That being said there are some very tight lash cams that have been produced for a very long time now. 50 + years ago I had a cam that called for 0.010" on the intake Hot.
Stan.
Old 11-13-2021, 03:09 PM   #3
KRatcliff
Liked 534 Times in 143 Posts
You can talk to your cam manufacturer and ask plus you can play with it a little. I used .005 with my LT1 when I was running shimmed lifters and it really liked it. Coincidentally, I run exactly the same lash with my solid rollers now and same camshaft.
We must have shimmed the **** out of the old lifters.
KRatcliff is offline   Reply With Quote
Old 11-13-2021, 03:21 PM   #4
First thing you need to do so is, if the mystery engine builder can't tell you, if it's indeed solid lifter. If it is, 5 th o u sounds about right. You need some Lash but don't want to give up much lift if you can help it.
