Old 09-14-2021, 06:44 AM   #1
Bob F
Liked 16 Times in 11 Posts
Default Power glide 1st gear
What gear do you run?
How fast what weight and what’s your 60’ please..
Bob F is offline   Reply With Quote
Old 09-14-2021, 07:34 AM   #2
JeremyDuncan
Liked 355 Times in 80 Posts
Default Re: Power glide 1st gear
1.98
9.3x @ 3170lbs
1.26 60'
JeremyDuncan is offline   Reply With Quote
Old 09-14-2021, 01:09 PM   #3
Jeff Kempton
Jeff Kempton's Avatar
Liked 69 Times in 33 Posts
1.98 1st gear
11.3 @ 3140lbs
1.53 60'
Jeff Kempton is offline   Reply With Quote
Old 09-14-2021, 02:13 PM   #4
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
1.76 1st gear
1.54/1.55 60 ft
best et 11.02 @ 122mph
3400 lbs @ the starting line
69 Chevelle 'stocker' style w/ a trans brake for bracket racing
5.14 rear gear
30 x 9" Hoosier Bias Ply
Andy Friar
Andy Friar is offline   Reply With Quote
Old 09-14-2021, 09:30 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
1.98
9.68 @ 143
3185 lbs
Chevy V-6
You will find a 1.98 has the best gear split of all low geared PG ratios.
Adger Smith (Former SS)
Old 09-14-2021, 09:57 PM   #6
Bob F
Well it looks like I can change my 1.76 to 1.96 without too much worry then.
Old 09-15-2021, 01:50 PM   #7
AveryMcLawhorn
Liked 80 Times in 19 Posts
Bob the rear gear ratio also plays a huge factor into this. Should the question not be, what is your overall first gear ratio?
Avery G. McLawhorn
2166 Super Stock
AveryMcLawhorn is offline   Reply With Quote
Old 09-15-2021, 07:18 PM   #8
Bob F
I’d like to change mine to a 1.96 gear from what I’ve read they don’t take much power.
My 396 makes around 600 flywheel hp presently but doesn’t 60’ we’ll 1.45/1.47’s .
I’ve had an Ultimate converter on the shelf for a while.
Once I run that I can look at my next change.
Seems to be a few cars here with quite a bit more power than I getting it done with a 1.96 1st.
Old 09-16-2021, 03:12 AM   #9
Adger Smith
Bob,
When you go from a 1.76 to a 1.96 you may need a converter change to get the most out of it. Because of the gear ratio the converter will usually act a few hundred RPM tighter or it might be sluggish pulling off the 1-2 shift. It just depends on what you have and if the converter/engine likes the gear.
I always test one at a time. Watch your flash off the line and at the gear change. there could be a change.
Good luck.
Old 09-16-2021, 06:53 AM   #10
Bob F
Thank you Adger.
The overall is 4.57x 1.76=8.043 presently
