Old 02-26-2025, 11:15 PM   #1
CraigG
Liked 8 Times in 7 Posts
Default Preload on Ladder Bars affect Rolling Resistance?
Hey Everybody,
How much does Preload on Ladder bars affect rolling resistance?
Thanks., Craig
CraigG is offline   Reply With Quote
Old 02-26-2025, 11:28 PM   #2
Woodfin
Liked 288 Times in 109 Posts
Default Re: Preload on Ladder Bars affect Rolling Resistance?
My experience with ladder bars is good. I have built several and tuned several others. With each case, ladder bars work well once the car is sorted out and usually only require a slight pre-load, sometimes none if used with an anti-roll setup.
I am pondering your question and visualizing the preload, and I do not see a way that a slight preload would cause any rolling resistance. A slight preload in the rear will not change the rear axle alignment.
In my experience, anything beyond a slight preload to make the car drive straight points to other problems.
Old 02-27-2025, 10:35 AM   #3
CraigG
Thank you for your response - I am using 2 flats for the right side positive preload.
Craig
Old 02-27-2025, 10:39 PM   #4
Woodfin
Craig, that sounds reasonable.
Old 02-28-2025, 12:01 PM   #5
CraigG
Thank you that is very helpful.
