Old 08-04-2021, 07:11 PM   #1
Jim Cimarolli
Liked 166 Times in 46 Posts
Default 71 Olds 442 oil pan removal
Can the oil pan be successfully removed and replaced with the engine in the car? 455.
Jim Cimarolli is offline   Reply With Quote
Old 08-04-2021, 08:00 PM   #2
t.tosto
Liked 62 Times in 23 Posts
Default Re: 71 Olds 442 oil pan removal
Jim, worked at Olds dealer 1971-1978, found it easier to remove engine for oil pan removal. Crank throws and frame K-member make it very tight in vehicle.
t.tosto is offline   Reply With Quote
Old 08-04-2021, 08:17 PM   #3
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
^^^^^ my experience as well-easier to pull it out
Old 08-05-2021, 08:24 AM   #4
SSDiv6
Pan is too close to the crossmember. You either have to lift the engine or remove it. There is also the issue with the use of incorrect engine mounts. The big block engine mounts are different than the small block. I have seen a few guys that put small block engine mounts with a big block and it puts the engine even closer to the crossmember.
Old 08-05-2021, 09:26 AM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Didn't NHRA make a rule that allowed you to modify or fabricate a removable cross member so you could remove your oil pan ? That may be hard to do, on a A-Body GM car but once it is done, it would be easy to remove the oil pan .
Old 08-05-2021, 02:54 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Very similar to a Pontiac
A device was made that allowed you to push the engine up enough from the bottom to get the pan off.
It had chains that wrapped around lower frame and used a big bolt device to push the engine up under the balancer/front cover
I don't recall the exact details but it did work because I used it more than once in my days as a Pontiac dealership mechanic....Mid to late1970's....
Rich Biebel
S/C 1479
Stock 147R
Old 08-05-2021, 09:16 PM   #7
Jim Cimarolli
I worked at a Pontiac dealership too in 1979 and I remember the tool you are in reference to.
Old 08-05-2021, 10:30 PM   #8
mikeloge
Liked 129 Times in 35 Posts
No you can't
mikeloge is offline   Reply With Quote
