Old 07-06-2021, 03:21 PM   #1
dragracerray
dragracerray's Avatar
Liked 217 Times in 93 Posts
Default 350 Chevy cam core shortage
It seems like COVID is affecting everything. I need a new cam and lifters and Comp doesn't have any cores (cast or steel) until the end of August! Can you guys suggest an alternative cam company for Stock Eliminator camshafts? Anyone have a new one on a shelf for a 1980 350/190 engine? Thanks in advance! Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 07-06-2021, 03:26 PM   #2
SSDiv6
Default Re: 350 Chevy cam core shortage
Have you contacted Bullet?
You may need to go with a billet core which I believe there may be some cores still out there. With a billet core, you will need PPPC lifters.
Old 07-06-2021, 05:01 PM   #3
dragracerray
Thanks just got off the phone with Bullet. They have solid lifter cast cam cores in stock. Apparently they do not use a core for solid lifter steel cams. They start from billet to make a steel solid lifter cam. Ray
Ray Bassett
Old 07-06-2021, 05:31 PM   #4
voltdr
Liked 100 Times in 51 Posts
Clay Smith Cams. 714 523 0530
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 07-07-2021, 01:46 PM   #5
pro stock chuck
pro stock chuck's Avatar
Liked 53 Times in 17 Posts
give a call I have 390/410 lift cams (14) of them. chuck 714 612 2625
pro stock chuck is offline   Reply With Quote
Old 07-08-2021, 07:01 AM   #6
G money
Liked 13 Times in 13 Posts
I have some on the shelve just let me know what duration & centerline you are looking for. Gary Walters 203 9432934
G money is offline   Reply With Quote
Old 07-31-2021, 05:37 PM   #7
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Try Clay Smith. I needed a hydraulic roller for a BBC street/strip car. No holdup. They had cams & lifters.
I had selection narrowed down to Crower or a Clay Smith custom. Crower had no cam cores.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 07-31-2021, 07:01 PM   #8
dirtmod18
Liked 11 Times in 4 Posts
Didn't hear much about the core shortages but we have been feeling the pinch so bad for solid flat tappet lifters for the past couple years, out of stock or piss poor product failures, (as we do mostly limited circle track engines) We have invested in the machinery and are now producing our house brand of flat tappet racing lifters. Everyone told me the cost would out weight the gain, but with the failure of several brand X junk flat lifters ruining entire engines, seems we are starting to see the light on start up costs already.
dirtmod18 is offline   Reply With Quote
