Liked 20 Times in 15 Posts
stock factory converter...is there any difference between a 6cyl and a V8 converter? size looks to be the same. how about stall or fin angle.
I have 4, of which I am going to sell 3 to a trans co. 1 is an air cooled 6cyl. others, not sure without pulling the input. and I dont want to do that if there is no difference between the 4. just looking for 1 that might be out of the ordinary. thanks Rod in AZ |
Liked 5 Times in 4 Posts
Not too sure I know years ago people ran opel converters because they stalled higher this was back in the 80s.
Liked 67 Times in 28 Posts
We ran 6 cylinder PG converters in our bracket car in the early 70s. Was good for about 2500 with a 396-325 engine. Chiseled off the heat/cooling shield.
#4 | |
You may be thinking of the Vega converter. Piece of junk, but what would you expect?
#5 | |
Liked 520 Times in 176 Posts
Any OEM 13" is only worth something to (maybe) a collector for a restoration project. |
Liked 172 Times in 81 Posts
4 cylinder and smaller 6 cylinder engines came with an 11" converter, V8's and some bigger 6's came with a 12". All air cooled ones were 11". Way back we used the 6 cylinder ones for a higher stall before the Vega ones came out. Vega ones worked good behind a big block but had a very short life.
Jim Mantle V/SA 6632
Jim Mantle U/V/SA 6632 |
Actually, I should have stated that the Opel converter was from the T180, which was also used in many small engine RWD cars , including the Chevette.. none of which could be used for racing, without extensive modifications.
https://en.wikipedia.org/wiki/Turbo-Hydramatic_180
Yep your right Vega converter
