Old 12-12-2020, 03:31 PM   #1
Lyn Smith
Liked 997 Times in 201 Posts
Default Edelbrock 1406 AFB question
I have a newer Edelbrock 1406 carb on a street car. I had it apart chasing a stumble, and no accelerator pump squirt. Under the acc. pump nozzle is a little brass looking needle (flat on each end though) with a ball under it. The Edelbrock carb book shows in multiple illustrations of a small spring under there also. Can someone tell me what is suppose to be there? Spring, ball, needle, and in what order??? thanks
Old 12-12-2020, 10:46 PM   #2
jim morgan
Liked 52 Times in 9 Posts
Default Re: Edelbrock 1406 AFB question
Brass weight and ball sounds right , check accel pump or passage
Jim Morgan 1916 , 9916 STK
jim morgan is offline   Reply With Quote
Old 12-12-2020, 10:59 PM   #3
Dissident
Liked 73 Times in 36 Posts
Ball on bottom, weight on top....no spring necessary.
Rgds,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 12-13-2020, 10:50 AM   #4
Lyn Smith
Thanks for the feedback. I found another 1406 that looked to be never taken apart and it had the ball with the little check on top. But in the SA Design Carter/ Edelbrock carb book, it shows in numerous images of them dropping in the spring with the ball on top. Crazy.
Old 12-13-2020, 08:04 PM   #5
Dissident
RE: Confusion over 1406 parts....Not Crazy at all
Having had some experience with editors/publishers on this kind of problem, the human side of the equation is the most difficult to balance..... Always best to consult manufacturer's instructions / manuals.
Edelbrock Owner's Manual for Performer Series (includes the 1406): Page 8 and page 33......clearly show ball on bottom, weight on top, no spring. Experience absolutely backs up this order of parts as well.
Regards to All that like this kind of stuff,
HB2
Dissident
Old 12-14-2020, 12:51 PM   #6
Jack Foshee
Liked 18 Times in 7 Posts
Lynn, I have had them with and without little spring,just ball and check valve, works fine
Jack Foshee is offline   Reply With Quote
