Liked 6 Times in 6 Posts
I wanted to get some input on a 16 volt system with alternator. Late model F body stocker with 16 volt batteries and powermaster XS alternator. I also have a voltage step down box 25 amp continuous. My question is if the components will handle the 18.6 volts while charging. I realize the gauge lights and small things will need to be stepped down but what about the injectors, starter, Fast XFI ECU, MSD7AL,e shift and valve body,etc.I have heard those components will have no issue at 16v but not sure with the added charging volts Thanks in advance for any help.
Liked 239 Times in 90 Posts
Save yourself the trouble and please shut off the master switch when charging the batteries. If the charger spikes, it will take out all kinds of stuff
the alternator should not charge voltage that high. If it does check to see if it is adjustable. Anything over 18 will likely spike a Fast ecu driver
#4 | |
Sponsor
Liked 717 Times in 121 Posts
Turning off the charger while cranking solves this. Some smart coils (IG1A) have issues over 17 volts. They can shut off. Most of the GM smart coils are ok. Robin
STK 308 SS 3088 |
That voltage is what I have read online. Alternator is adjustable from 13.5 to 18.6. My thoughts were to set to 16 volts and charge between rounds with switch off. I figured anything much above 16v would start frying things. Manufacturer of Electric fan (Deraile) states it will burn up at 16v.
#6 | |
Liked 167 Times in 81 Posts
Tim Schmackpfeffer 762 SS |
I realize that point. My main question was at what point of voltage would you be concerned about component damage running with an alternator to charge the batteries.
Liked 229 Times in 71 Posts
You shouldn’t have any issues mine charges at 18 with the powermaster adjustable alternators and really don’t need to charge it. I would suggest checking your alternator rpm you may want a larger pulley to prevent it from spinning too fast. Since it is adjustable if you would prefer to lower the setting to around 17.2-17.5. However, under a load it won’t be that high.
#9 | |
Liked 299 Times in 48 Posts
Like the Puppy said, the Powermaster alternators can work so well that we rarely ever put a charger on the car anymore. With dual 16v batteries the system all runs very well.
What class are you going to be running with your Firebird LS1Racer? Always like seeing more of these cars in Stock, hopefully things are going well for you! Mike |
