Old 10-10-2020, 03:13 PM   #1
hilton
Liked 18 Times in 8 Posts
Default Crank Trigger Adjustment
I've never seen this mentioned before, When you set your timing on your crank trigger then set the distributer on number one plug how far can you advance or retard the crank trigger before you have adjust the distributer again ? Or you must adjust the distributer every time ? Thanks< By the way I'm not talking big changes just 2 or 4 Degrees
hilton is offline   Reply With Quote
Old 10-10-2020, 04:01 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,240 Times in 986 Posts
Default Re: Crank Trigger Adjustment
If you move it over 2 degrees I believe you need to check rotor phasing. I’ve got a complete tutorial somewhere and will find it if needed.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-10-2020, 04:51 PM   #3
hilton
Thanks, Jim that answers my question I watched the Msd instructional video
