Old 10-12-2020, 07:32 PM   #1
2fast
Default Throttle stop time
Sc dragster electric stop turning it on at .100, how fast can you turn it on before it effects reaction time?
2fast is offline   Reply With Quote
Old 11-06-2020, 11:20 PM   #2
Superstreet29
Liked 4 Times in 4 Posts
Default Re: Throttle stop time
Following. I turn on at .05 and shift at .05 in Super Street and I’ve wondered the same thing.
Superstreet29 is offline   Reply With Quote
Old 11-07-2020, 10:16 AM   #3
pmrphil
Liked 348 Times in 152 Posts
A lot depends on how high you leave, if you're on a chip or converter, hardtail or suspended, and gearing. Test, test, test.
Phil Molski
PMR Performance
S/C 1623
Old 11-07-2020, 10:17 AM   #4
J&S Racing
Liked 319 Times in 82 Posts
I come on at .000 still have .020/.028 delay to not go red
Fwiw max speed TS leave 5k, hard tail 4:30 and I just tickle the stage bulb.
1 thing I don’t like about the electric TS is you can’t adjust the on off speed. I gotta imagine that make a difference how soon you can turn it on.
Old 11-07-2020, 12:16 PM   #5
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
My personal opinion is that the difference there is far overblown.
Electric is my preference although I do have CO2 on the dragster, with no flow control valves.
I didn’t play around with turning the throttle stop on at various increments, but I did have trouble on the tree turning it on at .010 so I went to 0.100 and it was good.
S/ST 51
S/C 53
Old 11-07-2020, 01:30 PM   #6
J&S Racing
[QUOTE=Lenny5160;627477]My personal opinion is that the difference there is far overblown.
This may be true with a under carb style stop but the Max speed is a different animal.
Old 11-09-2020, 12:54 PM   #7
Lenny5160
Lenny5160's Avatar
My dragster has an in-line stop with alcohol injection; it's going to react as violently as anything out there.
In a typical baseplate application, especially with most people coming off the stop in high gear, I wouldn't hesitate to use an electric stop.
S/ST 51
S/C 53
