Liked 68 Times in 22 Posts
Anybody ever put a little bit in your fuel cell when chillin the motor? When chilling do I need to richen up the motor. Lt1 combo. 12.9-13.1 is my AFR.
Liked 33 Times in 17 Posts
Yes and it is not advisable.
Lol. Thanks. You sound like you are talking from experience.
You have a message.
Liked 109 Times in 38 Posts
I was asked if I had done that when I was borderline on a fuel check once.
Al Wilson NSS 7160 W201 stock |
Liked 40 Times in 26 Posts
Wondering, can the dry ice be placed in a secure container then placed in the fuel cell, then removed before starting the engine for the race?
Liked 931 Times in 265 Posts
Is "artificial cooling" not legal? Is fuel temperature not a part of fuel check?
Just asking. |
Liked 355 Times in 80 Posts
Liked 162 Times in 45 Posts
You MUST remove the foam! MUST. The dry ice has nothing to do with water so it won’t dilute the fuel and will be gone by fuel check. They check fuel temp after the run to determine the correct chart to use for the fuel check. If you refrigerate your gas and use a cool can it’s pretty cool anyway.
Liked 27 Times in 14 Posts
Ever had that feeling in your stomach from too much acid and its bubbling?
