Old 07-31-2020, 07:09 PM   #1
Bernhard
Default Harmonic balancer weight and its effects ???
Harmonic balancer weight and its effect on performance?
If one reduces the balancers weight and makes correction to any imbalance
on the crankshaft.
Might one see an increase in HP and how quick the engine spins up?
Thanks
Bernhard
Bernhard is offline   Reply With Quote
Old 07-31-2020, 08:06 PM   #2
L.Fite
Liked 498 Times in 244 Posts
Default Re: Harmonic balancer weight and its effects ???
Theoretically yes... enough to notice?... I doubt it.
How much can you take off a balancer?... a lb maybe?
It's not like taking 10 lbs off of a flywheel.
Just an opinion, others may know more.
L.Fite is offline   Reply With Quote
Old 07-31-2020, 09:20 PM   #3
Ed Wright
Ed Wright's Avatar
The above, and the smaller diameter of a dampener, versus a flywheel, the effect on inertia won’t be big.
Ed Wright 4156 SS/JA
Old 07-31-2020, 10:00 PM   #4
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Exactly. Plus it also depended on how fast the rate of acceleration of the engine is. A 1 lb weight on the outside of a 6" diameter accelerating at 2000 RPM per second at 7000 RPM is taking less than 0.54 HP. Where as that 1 lb on the outside of a 12" diameter accelerating at 2000 RPM per second at 7000 RPM is taking 2.17 HP.
Stan
Old 07-31-2020, 10:34 PM   #5
Cotten
Liked 565 Times in 70 Posts
I put it in the category of things that dont show a measurable increase but when added to 50 other things like that, all of a sudden your a little faster. Lol
Cotten is offline   Reply With Quote
Old 08-01-2020, 11:06 AM   #6
Bernhard
Thanks you for your insightful replies to my question.
Bernhard
Old 08-01-2020, 11:32 PM   #7
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
I'll add a couple things with no verifiable info to suggest I'm correct however.. Almost all balancers are neutral or zero balanced so a change won't affect anything internal. Smaller/lighter should spin up faster but as mentioned, you'll never notice it. What is important is the name "Harmonic". A small lightweight balancer can't control internal harmonics like a heavy "factory" one does. Bearing or crank failure can be the result. Some engines and balancer brands are notorious for this.
Hopefully, a real expert chimes in here but i can guarantee you'll se nothing performance wise. Kinda similar to Roller Rockers that are magically going to add HP> JMO
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 08-02-2020, 02:34 AM   #8
GTX JOHN
Liked 2,490 Times in 700 Posts
I put in category of things that don't show a measurable increase but when
added to 50 other things like that, all of a sudden you're a whole lot poorer. Lol
AND THEN = Your crank is in two pieces!
John Irving
741 Stock
741 Super Stock
Old 08-02-2020, 10:37 AM   #9
L.Fite
Originally Posted by GTX JOHN View Post
I put in category of things the don't show a measurable increase but when
added to 50 other thing like that, all of a sudden your a lot poorer. Lol
Remember back in the days before ATI balancers when we cut the ring off the hub so the balancers wouldn't explode and kill the starting line crew?...
Ended up with stock in Federal Mogul and had lots of two piece door stops!
Old 08-02-2020, 01:10 PM   #10
Fireofficer5
Liked 33 Times in 20 Posts
Laughed so f#$%in hard.
Fireofficer5 is offline   Reply With Quote
