Old 07-20-2020, 10:22 AM   #1
Randy E
Liked 16 Times in 10 Posts
Question Surging QD 7500
I have a QD 7500 with about 2100 hours that surges and does not support a load when first started. If you shut off the generator and restart it, then it runs normal and will run everything it is hooked to. It acts this way if it has been shut down for over an hour or more, hot or cold. It is installed in a enclosed living quarters trailer. Any ideas? Randy E
Randy E is offline   Reply With Quote
Old 07-20-2020, 10:40 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Surging QD 7500
Fuel filter would be the first thing to change.
Check fuel lines and fittings....cant have any loose fittings that allow it to draw in any air.
Oil too full....It only takes 3 qt's...
Engine speed is controlled by the control/inverter and powers a stepper motor on the injection pump.
Kubota 3 cylinder engines are generally very reliable.....
Its an odd scenario.....
Clean fuel, no air in the system and no restrictions like in the filter. They are pleated paper inside and can get very bad....
I sometimes advise people to drop the fuel lines in a 5 gallon can of fresh fuel right near the generator. See if it makes a difference. Helps to eliminate issues with the fuel tank and lines.....I've seen problems there.
I recently had someone call with a 10 or 12 kw Onan that would not start. It had been sitting a long time......
Injection pump rack was stuck internally.....fuel could not be supplied to the injectors....
Rich Biebel
S/C 1479
Stock 147R
Old 07-20-2020, 02:56 PM   #3
Randy E
Thanks, Rich. I'll check out fuel system. It also had a couple codes, I think 33 and secondary either 12 or 21, can't remember right now. Randy Eakins
t
Old 07-20-2020, 03:04 PM   #4
Randy E
t
