Old 10-30-2007, 02:49 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default Help with Gas tank
I don't want to run a fuel cell, so I am looking for someone who can modify my stock pickup to an AN fitting also maybe incrse the size of the pickup.
TIA
Dave
Old 10-30-2007, 03:37 PM   #2
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: Help with Gas tank
A good radiator shop can do that mod....
Old 10-30-2007, 03:58 PM   #3
SSDiv6
Liked 1,538 Times in 575 Posts
You can remove the original pickup and drill it for an AN bulkhead fitting. Then use aluminum tube with AN tube fittings for your pickup.
Check out these site for ideas.
http://www.cowboyplayground.com/public/dp.htm
http://para.noid.org/~lj/Fuel/fuelfor600.htm
Old 10-30-2007, 04:00 PM   #4
Bill Belden
Bill Belden's Avatar
Dave,
take the sending unit out and cut off the fuel lines on both sides, then drill it out for a bulkhead fitting either # 6 or # 8 depending what size line you want. Use steel tubing to replace the inside line, flare the end and secure it using a tube nut.
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 10-30-2007, 04:04 PM   #5
SSDiv6
Originally Posted by Bill Belden View Post
Dave,
In lieu of steel tubing, I would recommend the use of aircraft aluminum tubing. Does not corrode, lighter and absorbs vibration and harmonics without breaking at the fitting.
Old 10-30-2007, 04:15 PM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
I have also used copper tubing bent to shape and soldered in place through the flange for the pickup tube. I believe GM solders the steel tubing in place from the factory. You can even solder the float sending unit onto the copper tube and have the stock fuel gauge work.
Old 10-30-2007, 05:36 PM   #7
David Lee
Dave,
Thanks to everyone who gave me advice on this. Time to have some fun fabbing.
Dave
