Old 06-24-2019, 11:49 AM   #1
FSA1673
Liked 12 Times in 6 Posts
Default ATI Trans Fluid
Anyone ever switch between the Super F and the Max Duty Super F and see a difference in stall rpm or % slippage. Looking to tighten things up a bit on the converter.
FSA1673 is offline   Reply With Quote
Old 06-24-2019, 12:49 PM   #2
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: ATI Trans Fluid
I would also be interested making converter a little tighter. I think trans fluid comes in different viscosity and seeing if anyone has any experience in this. Thanks Jeff
Old 06-24-2019, 01:50 PM   #3
nhramnl
Liked 358 Times in 83 Posts
Obviously, any info you gather here (from racers) will be helpful, but I would call ATI and ask them what they've heard from customer/users, and based on that, what they would expect you to see.
Old 06-24-2019, 08:53 PM   #4
monte385
Liked 27 Times in 19 Posts
Try some Mobil 404 hydraulic oil.
monte385 is offline   Reply With Quote
Old 06-25-2019, 10:36 PM   #5
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
It will tighten up the converter but not a set amount. Every combination will be a little different.
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 06-26-2019, 08:05 AM   #6
FSA1673
Thanks Marty that is exactly what I was looking for.
The kinematic viscosity of the Max Duty is similar to heavier hydraulic fluids such as John Deere Hy-Gard and Allison Transynd. Most regular trans fluids regardless of brand have similar kinematic viscosity. I imagine it depends on weight, rpm, and torque on what the converter will see.
Old 06-26-2019, 12:26 PM   #7
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Also what happens to different fluids at different temperatures.
Old 06-26-2019, 01:42 PM   #8
FSA1673
Most manufactures post their kinematic viscosity at 40 and 100 degrees so that you can compare them.
Old 08-01-2019, 10:24 AM   #9
Jim Kaekel
Liked 535 Times in 110 Posts
Torco also offers low and high viscosity ATF as well.
Jim Kaekel 3836 STK
Old 08-02-2019, 08:01 AM   #10
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
Thumbs up Re: ATI Trans Fluid
If you do plan on trying the heavier oils, make sure you use a screen type filter, not fabric type
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
