Old 09-11-2019, 12:54 PM   #1
Wayne Scraba
Liked 161 Times in 45 Posts
Red face Line Lock Plumbing?
Hi. I plumbed a Line Lock like this (below). It seemed like a clean way to plumb it without using a "T" inline. This saved a couple of potential places to leak . But now someone mentioned to me that with the way I plumbed it, there won't be sufficient pressure to hold the car while doing a burnout. So should I plug one of the outlets on the Roll Control and "T" out of one port only?
Thoughts?
Wayne
Wayne Scraba is offline   Reply With Quote
Old 09-11-2019, 01:56 PM   #2
Eman
Liked 133 Times in 76 Posts
Default Re: Line Lock Plumbing?
Pressure is pressure, doesn't matter if you had a T or used the LL body as the T, Once you activate the solenoid you pump the pedal and the LL is a one way check valve.
Old 09-11-2019, 02:14 PM   #3
Wayne Scraba
Thumbs up Re: Line Lock Plumbing?
Thanks! My thoughts exactly, but it seems I'm second guessing myself......again (not unusual in my world...L-O-L).
Wayne
Old 09-11-2019, 02:40 PM   #4
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
You may want to add a small rubber pad to insulate the line lock from the fender well. This way you eliminate or lessen any vibrations or stress on the lines.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 09-11-2019, 02:54 PM   #5
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Mine is plumbed the same way. Working fine. Looks great!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
