Old 04-15-2019, 11:37 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default NMCA class?
Have LT1 camaro. What is engine spec,weight , weight break, etc for C/FIA? Thanks
Kdw1403 is offline   Reply With Quote
Old 04-16-2019, 10:06 AM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: NMCA class?
Should be the same as C/SA..
D
Old 04-16-2019, 08:12 PM   #3
Kdw1403
Not sure if same as c/SA. Has a 11.90 index. I guess I’ll call nmca direct. Anybody else ever run c/fia. ?
Old 04-16-2019, 10:08 PM   #4
Dan Fahey
Dan Fahey's Avatar
Well it is an IHRA index whic are typically 3 tenths slower than NHRA.
Even Pure Stock and Crate Motor are light by that amount.
Old 04-16-2019, 10:09 PM   #5
Whalen3186
Liked 109 Times in 32 Posts
I’m fairly certain that if a car has an NHRA class that you have to run it instead of the IHRA class. I didn’t see a clarification listed in the S3 rules but I think Gene has posted it on here before.
I’ve only ran a couple of NMCA races and have ran B/SA each time instead of B/FIA, also with an LT1. IHRA HP rating is more favorable in most cases.
Whalen3186 is offline   Reply With Quote
Old 04-17-2019, 10:47 AM   #6
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
NMCA follows the old IHRA class indexes
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 04-18-2019, 02:26 PM   #7
Mike Washington
Liked 6 Times in 2 Posts
https://www.nmcadigital.com/2019-eve...rules-payouts/
Click on the link and then click on the 2019 S3 Stock/Super Stock Combo rules.
C/FIA has an index of 11.90
Mike Washington is offline   Reply With Quote
Old 04-18-2019, 10:30 PM   #8
Kdw1403
What is the horsepower rating of a 1997 LT1 in IHRA. I know NHRA rates it at 358.
Old 04-18-2019, 10:38 PM   #9
Whalen3186
IHRA had LT1’s at 331
Old 04-18-2019, 10:42 PM   #10
Kdw1403
Thanks
