Old 09-22-2007, 01:23 PM   #1
art leong
Default Cylinder head epoxy?????
I had to modify an oil passage on my aluminum head. A small part of the head surface goes beyond the block. Maening I'll have to fill it with something To stop an oil leak. This is an oil drainback passage not a pressure passage.
I have to seal an area about 1/2 inch square by about .070's deep. This is on the head to block surface of the head. Don't want to weld it because the head is finished and don't want to resurface it.
. There isn't a lot of heat there its right next to the water jacket. What type of epoxy should I use? Or should I just use rtv sealant?
Old 09-22-2007, 04:50 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: Cylinder head epoxy?????
JB Weld. I've used the stuff many times and it holds. It withstands heat and liquids with no problems. Clean it good...mix the stuff up and fill the area and after it sets up a short while you can shape it close.....after it sets completely (24 hours) sand it or file it flat.....
Rich Biebel
S/C 1479
Stock 147R
Old 09-22-2007, 05:09 PM   #3
Woodro Josey
Liked 3 Times in 1 Post
Also Rich, the Moroso 2 part A and B epoxy is really good!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 09-22-2007, 05:19 PM   #4
Rich Biebel
Hi Woodro.....how are you? I never tried the Moroso stuff but have seen others say it works good too. Devcon also makes all kinds of epoxies that work well. What do you think of the rules changes for next year? I should be at Atco right now but my trailer is down at the moment and I have a day with my son planned for tomorrow.....We are going to a Yankee game in NY.......
Rich Biebel
S/C 1479
Stock 147R
Old 09-22-2007, 06:36 PM   #5
Class guy
This
http://www.por15.com/prodinfo.asp?grp=PP&dept=10
is the best stuff I have ever seen or used.
Does not crumble or deteriorate like JB Weld over time.
Expensive but well worth it.
Class guy is offline   Reply With Quote
