Old 05-13-2019, 02:28 PM   #1
Eman
Liked 133 Times in 76 Posts
Default Oil bypass, do you block it?
On a SBC the oil bypass is in the oil filter adapter, I'm not sure on other motors. Do you block it to avoid oil bypassing the filter? I've read info arguing both ways.
Old 05-13-2019, 04:41 PM   #2
voltdr
Liked 100 Times in 51 Posts
Default Re: Oil bypass, do you block it?
I block mine. You must run an oil filter capable of handling the increased flow through it. I use the K&N HP3002.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 05-14-2019, 07:39 AM   #3
BillK
Liked 30 Times in 17 Posts
I have blocked a couple for customers that wanted them that way but like Dan said you absolutely must run a good racing type filter and be willing to warm the engine up some before getting your foot in it.
I have also seen two nice engines ruined because the owners used a cheap filter that came apart and blocked the oil passage going into the block
Bill Koustenis
BillK is offline   Reply With Quote
Old 05-14-2019, 09:24 AM   #4
Eman
I've blocked them in the past and used Wix filters, both standard and racing. I've never had any problems but it does make sense that the oil can't pass through the filter fast enough especially on launch. Cold oil and high viscosity would also slow the flow through the filter with no bypass.
Old 05-14-2019, 12:04 PM   #5
carl hinkson
Liked 18 Times in 10 Posts
I have block all of mine and use 1061 NAPA gold as it has a 19 micron rating VS the filters which have a 51 Micron rating.
No issues to date.
carl hinkson is offline   Reply With Quote
Old 05-14-2019, 11:47 PM   #6
RULER
Liked 58 Times in 18 Posts
Dirty oil is better than no oil.......
RULER is offline   Reply With Quote
Old 05-15-2019, 07:26 AM   #7
carl hinkson
A good case here. You have to know what your doing when building an engine and what parts to use,
I have always blocked the bypass and no problems to date, If you know what your doing it works.
Old 05-19-2019, 06:56 PM   #8
Ed Wright
Ed Wright's Avatar
Been blocking mine for over thirty years, never an issue. Clean oil.
1061 NAPA filters. Made by WIX.
Ed Wright 4156 SS/JA
Old 05-19-2019, 08:57 PM   #9
carl hinkson
Originally Posted by ed wright View Post
been blocking mine for over thirty years, never an issue. Clean oil.
1061 napa filters. Made by wix.
x100000000000000000000000000000000000000000
Old 05-20-2019, 02:53 PM   #10
Eman
Interesting how now word is that Wix has been manufacturing out of the country and quality has dropped. Anyone have any info on Wix quality?
