Old 08-14-2018, 02:44 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default MSD ignition coil ground wire
Some MSD coils are packaged with a ground wire that jumps around the rubber mounts to ground the coil body. What is the function of that ground wire?
Larry Woodfin 471W
Old 08-14-2018, 03:04 PM   #2
FED 387
Liked 330 Times in 178 Posts
Default Re: MSD ignition coil ground wire
Larry. It's an insurance wire to make sure you have the coil properly grounded thru the isolation mounts also helps eliminate tach signal issues--- Dick
