Liked 10 Times in 5 Posts
On a 360 mopar super stocker, having an issue with no. 3 rod oiling. Now trying reaming oil feed passages on no 2 and 4 to the mains and restricting oil to the cam bearings. Would cross drilling No.2 main bearing journal be a good thing to try also? I've heard good and bad things about cross drilling. Thanks for any opinions.
Liked 19 Times in 9 Posts
There are several factory fixes for inadequate oiling to the rod bearings. Basically restrict oiling to the lifter bores especially the passenger side should help. Do not restrict oil to the rockers.
I used to sleeve the lifter bores, all of them and let splash from the rockers oil the roller lifters. A second method I used was that I reamed and sleeved the passenger side oil bay with a copper tube. You can also add a supply line from the passenger side bay to the drivers bay as another method. This seems to work well but I never did it. Simple if you have a hydraulic or solid lifter cam. In a super stock motor I would also use babbit bearings. Set them up a bit loose like .003. Use a factory racing manual to properly size all your oil passages, especially from the passenger side oil bay to the mains and again up to the cam shaft and rockers. Pretty sure you need more oil. What oil pan are you using? |
Liked 890 Times in 248 Posts
In my experience, at higher RPM (7k+), these 360s get to be a problem. I've tried it all, including crossdrilling the crank, which didn't help me. Getting max solid oil to both ends of the crank is part of it. Limiting the amount of oil being bled off the mains to the cam and the heads is a larger part of it. Left oil galley needs to be plugged. Doing the tube in the galley trick is a mess. Have the lifter bores bushed instead. A number of different patches/fixes for this if you Google around some of the Mopar forums.
I set a #3 rod free this spring... My plan is to restrict the oil to the lifter bores via tubes in the gallery and use full grooved mains.... I'm also considering putting in a cross over tube. Yes these oiling systems suck...
#5 | |
A big problem are the 1/4 or 9/32" oil leaks from the main bearing bores to the front four cam bearings. All that oil going up instead of onto the crank needs to be addressed. Other problems are the rear main cap/oil filter mating surface and oil passages matching, oil passages in the back of the block need opened and massaged, and ensure no restrictions on the suction side of the pump. |
the oil pan that was on the engine was the engine guy's pan (rear sump truck pan with tube for steering link) now we are using a kevko pan. putting a tube in oil galley, no cross drilling crank.Did have fully grooved mains,will again too.
#7 | |
. Now with a flat tappet cam will there be enough splash oiling for the blocked off left side lifters? I would imagine the right bank would spray oil on to these lifters too... ?? |
Liked 53 Times in 38 Posts
Run down from the rocker oiling
These little modifications may also help?
Peter Ash 6100 STK Last edited by Peter Ash; 07-31-2018 at 11:51 AM. |
#10 | |
Just to clarify, the left (drivers side) galley is blocked off with a pipe plug in the feed passage at the #1 main bearing bore. Some people push a plug past the feed passage in the front of the galley under the cam thrust plate. But the plate isn't sealed to the face of the block and is another potential leak. Plugging at the bearing eliminates all of that. A crossover or direct bypass to the front of the right (pass side) galley is used in parallel with the galley and run from the very rear to the very front of the galley under the intake. This ensures that galley is fed equally well at both ends, and that the crank is oiled at the front as well. Plenty of oil being slung to oil lifters with the tubes or bushings. If the rocker gear requires pushrod oiling, the bushings can be drilled to provide that to the lifters and the left galley will have to remain fed from a crossover under the intake. Oil running to the cam from the main saddles still needs to be controlled to keep it on the crank.. The biggest problem I've had with pans is keeping the pickup submerged on deceleration. Different baffles and fixes were tried with varying success (or lack of it). I finally decided that an accusump, if allowed, or cutting the engine with a clean neutral was the best solution to that problem. Last edited by CMcAllister; 07-31-2018 at 03:00 PM. |
