Old 05-23-2018, 12:15 AM   #1
codywampler
codywampler's Avatar
Default Pros/Cons 9" Tire Hoosier or MT
Stocker guys, I have a small tire 69 camaro with caltracs that we are looking to bracket race. Which 9"tire does everyone recommend? Should you run them tubeless? I have run MTs before just never in a small tire. Thanks for you assistance.
God Bless,
Cody Wampler
http://www.facebook.com/wamplermotorsports
codywampler is offline   Reply With Quote
Old 05-23-2018, 11:11 AM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Pros/Cons 9" Tire Hoosier or MT
I recommend radials. I've had great luck with Hoosier and Goodyear; never run M/T but wouldn't be afraid to try them. They don't make the PBR in anything taller than 28" for a 9" wide tire, so I stick with Hoosier C07 92.5" circumference for now.
I strongly feel that the radials are superior if your car will work on them. Do a very small burnout and they will last just as long as any other tire. I feel that the radial construction and higher pressure make the sidewalls last longer than a bias tire with a heavy car.
S/ST 51
S/C 53
Old 05-23-2018, 11:48 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Pros/Cons 9" Tire Hoosier or MT
A bias ply will be more "forgiving" if the track isn't in the best shape. But as mentioned above, you can work on the car to make it work better with radials. Radials can also be a bit faster in ET and RT than bias.
The higher pressure will work better with a wider rim to help maintain a flatter footprint. That's why a lot of Stockers use 10" rims with 9" tires. I've run 9" Hoosier radials for a long time with good results.
LOCOMOTION Racing
Old 05-23-2018, 12:14 PM   #4
Lenny5160
Lenny5160's Avatar
Agreed. I started with 8" wheels but the footprint is much better with my 10" wheels.
S/ST 51
S/C 53
Old 05-23-2018, 12:25 PM   #5
Dave1695
Liked 15 Times in 11 Posts
I run a 29.5 M/T radial, tubeless, 10 wide wheel, on my small block 67 Camaro Stocker. They work great and they last if you drive them right. I tried other brands and always went back to M/T (my 50th year of racing). Just my two cents!
Dave1695 is offline   Reply With Quote
Old 05-23-2018, 11:25 PM   #6
codywampler
Thanks for the input guys. M/T offers a bracket radial. I guess that is a mix of the 2.
God Bless,
Cody Wampler
Old 05-26-2018, 10:29 PM   #7
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
Is it safe to assume this car is an automatic and not a stick car? Not to steal the thread but in the past it was always a no to radials on a stick car?
b.guggenmos is offline   Reply With Quote
Old 05-28-2018, 06:04 PM   #8
Liked 10,793 Times in 2,244 Posts
The most cost effective tire would be the 9" Goodyear radial, very little time in water box = less wear. I had a wire break on my line lock and only got to spin tires ( 2nd gear only ) and stage. Result 1.33 in 60', 10.17 @ 129.55. You can watch car leave on D3TV Friday Sportsnationals around 1:09 mark of the replay. And with me being 300 lbs the car is not 50/50.
Old 05-29-2018, 11:22 AM   #9
Lenny5160
Lenny5160's Avatar
I run Hoosiers and have not used a line lock in 15-20 years. A quick hit in Low to get it to 5000-5500, shift to High and drive it out. If the box was too dry and it doesn't want to spin, it doesn't matter. If there's breakage in the pair in front and you sit there for 15 minutes, doesn't matter. Stage and let it rip.
I'm off the transbrake going 1.39-1.41. Getting 200 runs on the tires is not an issue.
S/ST 51
S/C 53
Old 05-29-2018, 11:57 AM   #10
Demon340
Liked 108 Times in 29 Posts
With good traction, 9inch Hoosier radials were worth a tenth. In my case, with poor track prep led to a short spin then hook, causing 9teeth on the ring to break, inturn broke the trans as well. Expensive learning.
I dont think running the bias Hoosiers would have led to that. .
Demon340 is offline   Reply With Quote
