Liked 6 Times in 4 Posts
What do you all put in water in radiator to keep from getting rusty looking? I took motor out and apart for some head work and the water looks like it came out of a old tractor that been setting for years. Motor was only together for 9 months. It is a dart block
I use Water Wetter it seems to work pretty good.
Liked 120 Times in 53 Posts
How do you clean out a rusty cooling system like the one described above. I'm looking to clean it in the car, not tear down the engine. Thanks
Liked 346 Times in 126 Posts
I have not tried this product Thermocure made by evapo-rust but have seen it on tv looks to work excellent. Paul
Liked 1,040 Times in 369 Posts
https://www.summitracing.com/parts/jgr-50030
We used this for a while . Still have 5 or 6 bottles around here somewhere. Works well, but it foams a little in a unpressurized system ..We only used half a bottle per fill
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 02-13-2018 at 10:29 AM. |
Liked 1,959 Times in 593 Posts
I never leave the water in my engine
Mike Pearson 2485 SS |
Liked 706 Times in 283 Posts
I thought using thread cutting oil in radiator. 1 shot glass worth
#9 | |
Liked 921 Times in 260 Posts
I used Justice Brothers products because I sold them and they worked well. Any quality anti-rust product should prevent the coolant from turning to mud. |
Could you use CLR safely to clean? I always thought if you drain water and let metal sit exposed to air it would promote rust
