Old 03-02-2018, 05:38 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Sfi 200 metric case
I was looking to see how much interest there would be in an SFI approved TH 200 Metric case.
I would think with all the people using them in stock & super stock, a corporation that builds this type of case would stand to make a nice profit given the new 10.99 rules?
Would you buy one if it was available, instead of using a blanket or shield?
I'd take one!!
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 03-02-2018, 05:44 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Sfi 200 metric case
I see ATI just released a SFI case for a 350THM . They may be a good place to ask, if there is enough interest in the 200 .
Old 03-02-2018, 06:27 PM   #3
Lee Valentine
Liked 319 Times in 68 Posts
Seeing I have five th-200's I'd be good for 5.
Lee Valentine 1661 STK
Old 03-02-2018, 07:00 PM   #4
NHRA3106
Liked 147 Times in 38 Posts
I would be interested in one
NHRA3106 is offline   Reply With Quote
Old 03-02-2018, 07:05 PM   #5
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
be in for 2
jim powers is offline   Reply With Quote
Old 03-03-2018, 01:16 AM   #6
gtaa
Liked 4 Times in 2 Posts
I'll take 2
M.Lind D/SA
gtaa is offline   Reply With Quote
Old 03-03-2018, 02:48 AM   #7
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
The 350 case will not be available until end of season.
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 03-03-2018, 01:03 PM   #8
SSDiv6
While there is not an SFI case for the T-200, if you want a stronger case, if you can find one, use the BOP T-200-4 case that was used on GM cars that were powered with the Oldsmobile 350 Diesel engine.
The bellhousing and case is way stronger and even heavier because the additional material in the case.
Old 03-04-2018, 03:16 PM   #9
Two-Timer
I could use 2
Kevin Belisairo 589 J S/A
Two-Timer is offline   Reply With Quote
Old 03-04-2018, 04:22 PM   #10
Todd Hoven
Guest
Posts: n/a
The point of the SFI case is not only because it’s stronger, it is so you don’t have to purchase a blanket or shield. A different production case doesn’t solve this issue
QUOTE=SSDiv6;557372]While there is not an SFI case for the T-200, if you want a stronger case, if you can find one, use the BOP T-200-4 case that was used on GM cars that were powered with the Oldsmobile 350 Diesel engine.
The bellhousing and case is way stronger and even heavier because the additional material in the case.[/QUOTE]
